August 18, 2016, 01:53 |
Negative Total heat flux at inlet
Tleja
Rep Power: 12 |
Hi All!
I'm not familiar in heat transfer field. I'm studying fluidized bed reactor with transient study. In my system, solid particle was patched at the bottom of reactor. Then, i continuously fed gas and solid with 343K temperature. I also initialized this system with 375K. After starting calculation, i found that total heat flux of gas and solid at feed inlet are negative value. As my understanding, total heat flux should be equal to mass flow rate*heat capacity*(T in-T ref) which is certainly positive value. i also checked that mass flow rate of gas and solid at inlet are positive value. I don't know why total heat flux is negative value at inlet. Please anyone advice me to solve this problem. Thank you so much. Best regard Tleja |
Display Modes | |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
setting heat flux inlet boundary condition | eliminator | CFX | 6 | July 28, 2015 08:50 |
Udf for moving heat flux in 2D cylindrical geometry | devia21 | Fluent UDF and Scheme Programming | 0 | April 20, 2015 00:27 |
Total Surface Heat Flux | cfmyd | FLUENT | 0 | June 27, 2014 16:00 |
Total heat transfer through pressure inlet | Naher | FLUENT | 4 | June 13, 2011 10:22 |
