Home > Forums > FLUENT
Non-Newtonian power law: unable to define minimum and maximum viscosity
Old   September 5, 2015, 12:27
Exclamation Non-Newtonian power law: unable to define minimum and maximum viscosity
Simona is on a distinguished road
Hello guys!!!
I m a beginner in fluent and i really need your help for one project that i have!
My project is about:
Pipe with non Newtonian fluid inside i do not have the lenght of my geometry but my fluid is fully developed (that means that the pipe shoulb pretty long to have this condition right?)
Well i draw my geometry and than i start to use fluent whe i define material and i put "water-liquid" than i select "viscosity-> Non newtonian power law" and then i should have minimun and maximum viscosity, but i don't, and i really don't know which kind of values i have to put and in which way i ca ceck if they will be correct or not.Can you help me please? Thanks.
Simona is offline   Reply With Quote
Old   September 21, 2015, 00:13
Afiq Azmi
mafiq2000 is on a distinguished road
Hey simona , i'm also have problem same with you , untill now you have any solution to find maximum , minimum viscosity and consitency index for fluent ?
mafiq2000 is offline   Reply With Quote
Old   September 21, 2015, 05:47
Bruno Machado
Bruno Machado is on a distinguished road
For minimum and maximum you can conside the Pr of water divided and multiplied by 1E4 respectively. After that you can check if your Molecular Viscosity is located within this range.
Bruno Machado is offline   Reply With Quote
Old   September 21, 2015, 05:49
Bruno Machado
Originally Posted by Simona View Post
Hello guys!!!
you can write an UDF profile to set a fully developed flow regardless of the length of the pipe.
Thread Tools
Trackbacks are On
Get the maximum and minimum pressure in the domain(In parallel calculation) xh110120 Fluent UDF and Scheme Programming 4 October 10, 2014 08:06
defining consistency index (K) for non-newtonian power law fluids mdakbari FLUENT 0 July 11, 2014 04:36
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
CFD Post: Location of maximum and minimum velocities! JuPa CFX 6 August 31, 2012 09:51
new parameter for non newtonian power law model! Antoine FLUENT 0 July 21, 2008 04:30
