Fully developed 3d velocity profile: Square inlet!
Old   June 19, 2008, 08:32
Default Fully developed 3d velocity profile: Square inlet!
Taru
Hi
I need to simulate fully developed flow in a square channel, for which I need a UDF for obtaining the 3d velocity profile. The code itself is simple, however I'm unable to find a relation for velocity profile in a square channel. For a circular channel, it is simply the paraboloid U=2*Uavg*(1-(r/R)^2) But for a square channel (laminar flow) I do not know what would be the right equation to use.
Has anyone ever simulated this in a 3d square duct? I'd be really grateful if you could help me this.
I also tried solving analytically using the Navier Stokes equation but kinda got stuck at the PDE: Uxx+Uyy=K
Where U=0 at x=+/- a and at y= +/-a (a = 0.5* square channel side)
Would really appreciate a formula or code regarding this..
Thanks.
Old   June 20, 2008, 09:32
Default Re: Fully developed 3d velocity profile: Square in
Paolo Lampitella
Check White, Viscous Fluid Flow, p 120
Old   June 21, 2008, 15:41
William
Alternatively, just run a case where you let the flow fully develop, then record a profile of the fully developed profile and use that as a boundary condition for your primary case.
Old   June 21, 2008, 18:55
cfd.newbie
Alternatively use periodic/cyclic boundaries to get fully developed flow. If your flow is compressible then unfortunatley there is no short cut. You will have to do what paolo suggested. If you do come up with an equation, please let me know I have been looking for one for long time.
Regards
Old   June 21, 2008, 18:57
cfd.newbie
Sorry I meant what William suggested.
Regards
Old   June 23, 2008, 06:04
Taru
Thank Paolo, William and cfd.newbie.
For the moment I tried using the profile for circular channels as an approximation at the inlet (and letting the corners be zero) and since I had an entrance length of about 2.5*Width where flow could develop, I've got fairly good results. I had previously observed that using a uniform velocity at inlet wasn't sufficient, at least with this entrance length, but it was computationally expensive to use a larger grid for a 3d simulation.
Thanks William, the reference looks extremely useful, (also found it here: Three-dimensional simulation of square jets in cross-flow Sau et al (2004) PHYSICAL REVIEW E 69, 066302) though the equation is slightly complex.
Old   September 14, 2015, 08:38
Default Fully developed flow in Square and Rectangular Duct
Pravaah is on a distinguished road
You can find this relation in "Advanced Engineering Fluid Mechanics" by Muralidhar and Biswas.
I
Pravaah is offline   Reply With Quote
fully developed velocity profile in 3D S.S. Main CFD Forum 14 January 11, 2017 13:06
Udf for a fully developed velocity profile atinlet philip meppen Fluent UDF and Scheme Programming 10 November 3, 2015 15:56
fully developed velocity profile KS FLUENT 1 November 12, 2008 08:36
inlet velocity profile for fully developed turbule pankaj saha Main CFD Forum 4 August 24, 2007 16:53
Non-parabolic profile for fully-developed flow Adrian Lee FLUENT 1 March 18, 2004 05:14
