Non-newtonain turbulence
Old   September 18, 2015, 06:31
Default Non-newtonain turbulence
Cees Haringa
CeesH is on a distinguished road
Hello all,
I have a question related to non-newtonian fluids and turbulence. I know how to enable the model, but I cannot find in the FLUENT manual what the option 'enable turbulence for non-newtonain fluid' actually does (and what happens if you run a turbulence model + non-newtonian fluid without enabling this option)
Does enabling the option mean that the effect of the fluctuating strain rate is also included in determining the effective viscosity? Or will only the mean strain rate be included? If so, what is the difference with not enabling the non-newtonian turbulence option? Because when I leave it off, I do still get reasonable viscosity profiles in the domain and also the velocity profile is clearly affected.
Best regards
Cees
CeesH is offline   Reply With Quote
Old   September 28, 2015, 03:34
Cees Haringa
It seems there are no ideas?
Old   September 28, 2015, 07:51
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Hi Cees,
if you didn't already read this:
http://rheology-esr.net/Open_transac...20Karvinen.pdf
you can find some info starting on page 3 about turbulence for non newtonian fluids.
Maybe it is part or what you're looking for.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   September 28, 2015, 08:01
Cees Haringa
Hi Daniele,
I did not look at that yet no - so far I was trying to figure out the specific implementation in FLUENT. Thanks, I'll check it out!
Old   September 28, 2015, 08:03
ghost82's Avatar
Rick
I read the article fast, but at the end it seems it's related to polyflow (laminar simulations) and fluent (turbulence); so the description should be relevant to fluent, even if it was a very old version.
Maybe it can be usefull to start searching for other sources.
Turbulence postprocessing Mohsin FLUENT 2 October 3, 2016 14:18
Turbulence length scale Leonpolou FLUENT 2 January 23, 2013 07:26
How to implement turbulence in one Solver??? vahid.najafi OpenFOAM Programming & Development 0 July 29, 2012 05:46
Code release: Flow Transition and Turbulence Chaoqun Liu Main CFD Forum 0 September 26, 2008 17:15
How's going on with Turbulence Research? Daniel Main CFD Forum 1 June 20, 2008 23:44
