Transient Heat Transfer vs. RANS Heat Transfer |
October 5, 2015, 11:24 |
Jimmi
Rep Power: 13 |
I have an issue when simulating (LES) heat transfer of flow over a flat plate. Initally I have tried a simple RANS heat transfer case (similar to: https://confluence.cornell.edu/displ...t+Plate+step+6), which also references Reynolds, W.C., Kays, W.M., Kline, S.J. "Heat Transfer in the Turbulent Incompressible Boundary Layer." NASA Memo 12-1-58W. December 1958. I initially just used a constant wall temperature (around 400K) with inlet temperature of 300K, the Nusselt vs. Reynolds number matched with experimental. Switching to LES and time-averaged statistics in Fluent results in the Nu. number (calculated using the heat-flux) being approximately 1/3 that of the RANS case (for constant wall temperature). Is there any reason for the difference? Regards, Hob |
October 5, 2015, 19:27 |
Lucky
Rep Power: 65 |
This is an oversimplification but if you don't give perturbations to an LES simulation it relaminarizes and becomes an unsteady laminar flow. Do you have any perturbations? Check to see if you ended up with the laminar Nu and check to verify that you are actually doing LES and not an unsteady laminar simulation.
October 5, 2015, 19:44 |
#3 | |
Jimmi
Rep Power: 13 |
Exhaust Manifold Transient Heat Transfer Simulation | Jonny6001 | STAR-CCM+ | 9 | February 22, 2017 13:24 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
transient heat transfer analysis on Autodesk Mechanical | yasemin | Autodesk Simulation CFD | 0 | November 28, 2013 13:14 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
