Smoothing mesh and reading skewness in Fluent
Old   October 14, 2015, 03:40
Default Smoothing mesh and reading skewness in Fluent
Hannes
Stormbringer505 is on a distinguished road
I am working on my master thesis using Ansys Fluent 15.0, modeling a waterjacket for a biomass fueled boiler.
I have created a mesh using Ansys Meshing but I have some highly skewed elements in it (Skewness about 0.99). I've connected the mesh to Fluent in workbench and tried smoothing it (skewness-based) in serial mode. Then I have initialized the solution and computed the max. skewness (Graphics and Animations-Mesh-Cell Equivolume Skew) for all zones. It improved to about 0.9 and the equiangle skew to about 0.85 which is acceptable for me.
Then I've saved the project, switched to parallel mode and made some iterations. Even though the computed max. skewness of the mesh is at about 0.9 the solver is telling me that I have some highly skewed elements in the mesh with a skewness >0.98.
Can somebody please tell me what's wrong there? Thank you!
Stormbringer505 is offline   Reply With Quote
Old   October 14, 2015, 07:09
Hannes
I've solved the problem!
I had to adapt the mesh using fluent in serial mode, then I wrote a case file which I imported to Fluent in parallel mode.
Old   January 1, 2020, 14:37
Bran is on a distinguished road
Hi!
Could you explain why you had to adapt the mesh in serial mode opposed to parallel mode?
Bran is offline   Reply With Quote
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
