October 26, 2015, 08:30 |
Patching Zones - DISCONTINUITY at Borders
Gergö Schmidt
Rep Power: 10 |
Hi everybody
My problem is the following. I have two zones (z1 and z2). I patch two different pressure values (p1 and p2) to theese zones using "Solution -> Solution Initialization -> Patch". I want a discontinous pressure distribution on the border between z1 and z2 But Fluent produces a continous (smeared) transition on the border My question is therefor: is there an option for discontinuously patching values to zones? Or is there another way to assign initial conditions to zones? Thank you, kind regards, Gergö |
October 26, 2015, 12:54 |
Lucky
Rep Power: 65 |
I am assuming you correctly patched a discontinuous pressure to two different cell zones. If so, I don't think that is an actual problem. Recall that Fluent is a finite-volume solver with dynamic variables stored at cell centers. Nothing is stored on cell faces. Hence you cannot specify anything at a border between two cell-zones. The face values are computed from the cell values according to the discretization schemes. The only exception is if you have a boundary condition, then the face values are imposed. The transition you are seeing is a plotting problem. But if you think that the discretization schemes are not appropriate for your problem, then you have a much bigger issue to deal with.
October 27, 2015, 02:23 |
Gergö Schmidt
Rep Power: 10 |
Thank You, LuckyTran! I forgot the cell centred property of the solver. Only two rows of cells are affected by the transition, so you're absolutely right!
discontinuous, patch, pressure, smearing, zones |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
Initializing or patching cell zones | kozalp | FLUENT | 0 | December 30, 2013 16:00 |
patch error OF v2.2.2 mac | hewei | OpenFOAM Installation | 4 | November 30, 2013 16:55 |
2.0.x on Mac OSX | niklas | OpenFOAM Installation | 74 | March 28, 2012 16:46 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
