October 31, 2015, 10:16 |
qustion about move mesh
Rep Power: 13 |
I use Ansys Fluent 14 in a 2d case for a crossflow fan simulations. The rotary domain around the fan is connect with the stationary domain through the interfaces. The interfaces is a pair of circle connectors with the same radium and center so that I can keep there are no gaps between the interfaces. But after run this case about 6000 time-steps(about 40 periods). Gaps can obviously find between the interfaces. The velocity filed is broken near the interfaces. I am sure that the rotation axis is right. The gap is all around the inner interface and it seems that the radium of the rotary domain changed small.
It is really strange. I use the previous motion command to exam the mesh .I find if I use a large time step size and a small number of time steps the question will not appear. It seems that the size of gap is influenced by the number of time-steps . The RPM Is high in this case, a large time steps lead to convergence difficult. Is there anyone have similar experience ?can give me some suggestions? |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
