November 23, 2015, 10:23 |
unsmoothed contour of temperature
Lida
Rep Power: 11 |
Hi everyone
I want to model floor heating in a room in 2dimension mode. The floor heating part is in the center of the floor. The ceiling and other parts of the floor except the heating part are insulated, and the walls are at the constant temperature. There is convection in the room and the flow is laminar. When I model it in fluent 6.3.26, the contours of temperature are unsmoothed, but it is expected to be smooth. What should I change in order to have smoothed contours for temperature. I should say that I have used 10^-9 for the residuals. I will be thankful if anyone can help me solve this problem. |
November 23, 2015, 12:35 |
Rick
Rep Power: 26 |
please post a picture of your contours, so to better understand what you mean by not smoothed contour.
Google is your friend and the same for the search button! |
November 23, 2015, 15:50 |
Bhargav Bharathan
Rep Power: 10 |
If contour smoothening is your only issue, you can try Graphics > Contours > Select your parameters. On the left specify Levels = 40. -BB |
November 26, 2015, 01:43 |
Lida
Rep Power: 11 |
I tried this way but unfortunately it did'nt work. there is also another problem. the resulting nusselt number have 30% deviation from the true nusslet number.
November 26, 2015, 01:46 |
#5 | |
Lida
Rep Power: 11 |
IMG-20151124-WA0012.jpg |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
Export Temperature Contour | Ledeeb | FLUENT | 1 | February 22, 2015 15:02 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
Is wall ajacent temperature equal to conservative temperature of the wall? | shenying0710 | CFX | 8 | January 4, 2013 04:03 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
