December 2, 2015, 05:20 |
Electronic Equipment Cooling Issue
zion lee
Hello guys
I'm simulating an CPU cooling with heat sink in fluent My inlet condition was determined by considering fan blow. (Which means that i assumed to skip fan conditions) Instead of fan setting, I gave B.C at inlet with maximum velocity from fan's volume flow rate. And then I solved with standard k-e with Enhanced wall fcn + Energy Equation. The problem is that pressure at inlet is "lower" than outlet. But my velocity vectors seems correct (they head from inlet to outlet) So what is problem? Should I simulate my case with fan..? Any helps will be thankful!! |
Electronic Cooling | Chris Smoult | FloEFD, FloWorks & FloTHERM | 7 | October 15, 2012 08:47 |
Electronic Cooling using CFX? | Kratuan | CFX | 11 | July 13, 2008 19:50 |
Flotherm-Icepak comparison for electronic cooling | Masoud Ameli | FLUENT | 0 | February 28, 2005 09:00 |
PCM - Electronic Cooling | Esam Alawadhi | Main CFD Forum | 0 | April 2, 2000 02:11 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
