How to do Grid Independent Study
Old   December 2, 2015, 12:54
Default How to do Grid Independent Study
Terry
tsaget is on a distinguished road
Hi all,
I was wondering how do I do a grid independent study. I have ploughed through the forum several times and I could not find the answer I need. I understand that grid independence can be achieved by refining the mesh progressively. But how do I do so?
Take ANSYS FLUENT for example. There are so many parameters(eg. max face size, edge sizing, etc....)that can be used to refine the mesh. Which is the correct parameter that I should adjust?
Thank you!!!
tsaget is offline   Reply With Quote
Old   December 2, 2015, 13:02
Terry
In addition, do I do refinement at the workbench or Fluent?
Old   December 2, 2015, 19:27
Jeeloong is on a distinguished road
I think you should fix the first wall cell first then change the core mesh density to get a variable which doesn't change when solution converged.
Hope that helps
Jeeloong is offline   Reply With Quote
Old   December 2, 2015, 20:06
Terry
Hope that helps
Hi Jeeloong,
Thank you for your reply! May I ask how do I do so? Where do I adjust the wall cell and where do I change to core mesh density?
P.S I forgot to mention that my domain is rectangular and 2D.
Old   December 3, 2015, 06:05
Do it in pre-solver (Meshing tool) by loading the mesh file in the software.
Then change the spacing size of the cells either transverse or longitudinal.
Thanks
Hope it helps
having problems with performing grid convergence study in SWFS drdet FloEFD, FloWorks & FloTHERM 12 January 22, 2015 04:44
grid study, important question hamid1 FLUENT 1 August 4, 2013 00:14
Grid Independent Study for a car John222 Main CFD Forum 1 January 26, 2011 19:05
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 4 July 15, 2000 03:27
