December 19, 2015, 10:58 |
combustion of methane air in closed chamber
Sinar
Rep Power: 10 |
hello everyone, can any body help me. input value for species in initialization dialog box as in attached figure refer to what parameter? this is because, my mixture in closed vessel did not start to propagate the flame.
December 19, 2015, 11:10 |
Sinar
Rep Power: 10 |
hello everyone. my problem is to start the ignition of the methane air mixture in cylindrical closed vessel. I already try to patch high temperature at the small sphere surface at centre. however, the mixture combustion still not ignite. I using species transport model. anybody can help me to solve this problem? some time the flame start start at the cylinder wall.
December 20, 2015, 15:14 |
initial values
Diego
As I see you introduce a homogeneous mixture in the domain of ch4, o2, co2, h2o and n2. The sum of initial values of that components must result equal to 1. So I suppose the fisrt capture you send is wrong.
regards |
Appropiate BC's for the inlet/outlet in an air chamber | zfaraday | OpenFOAM Pre-Processing | 9 | March 15, 2018 08:17 |
[Other] How to define internal walls for injector inside a combustion chamber by OF2.1.1 with | sandy13 | OpenFOAM Meshing & Mesh Conversion | 0 | May 22, 2013 06:59 |
combustion chamber problem | mcnair | ANSYS Meshing & Geometry | 0 | March 16, 2011 12:41 |
Combustion in a closed System | Martin Castillo | FLUENT | 3 | June 20, 2007 21:38 |
Pre-heating combustion air | Eric | Main CFD Forum | 4 | November 13, 2003 03:19 |
