Divergence detected in AMG Solver:TEMPERATURE fsae body |
December 21, 2015, 13:34 |
BIANCA GIAROLA
Rep Power: 10 |
Hi!
I'm working on 2d flow simulation of a fsae body. Those are some informations about setup: Pressure based Viscosity model: spalart allmaras - vorticity based Density of an ideal gas Boundary conditions: free - pressure far field with 101325 for gauge pressure and 0.4066 for mach number After some iterations I have got the "Divergence detected in AMG Solver:TEMPERATURE". What can I do to solve this problem? Thanks in advance, Bianca |
December 21, 2015, 15:40 |
Cees Haringa
If you are running an ideal gas simulation, the simulation will keep track of the temperature too to abide PV = NRT. Of course, if you are not setting boundary conditions and so on for the temperature T, there may be some odd, unwanted effects of even divergence.
You can opt to simply initialize the simulation at a certain realistic temperature T, and disable the energy equation so the value of T remains fixed. This should remove such errors. Of course if you do not want an isothermal simulations, make sure all the conditions are set properly. |
December 25, 2015, 07:35 |
BIANCA GIAROLA
Rep Power: 10 |
In this case I don't want a isothermal simulation so T can't be fixed.
I checked all the values on the setup and I think those are correct, because the values were used on a airfoil's simulation, and for the fsae body the conditions are almost the same. |
fsae body amg solver |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
