What is the difference between pore diameter and particle diameter in porous media? |
January 9, 2016, 07:49 |
Rep Power: 14 |
I am modelling metal foam in fluent (Porous model) and I need to know the difference between pore diameter and particle diameter in porous media? And the difference between porosity and particle per inch designation and how to find the other when I have only one?
Thanks in advance |
January 10, 2016, 06:30 |
Fluent for Porous Media
Ray
Rep Power: 10 |
Hi Emara
Sorry, I am like you new here and in Fluent. But, as you are working with CFD in porous media, I just thought maybe I can ask you a question: how and where did u put porosity in fluent? How about cylindrical flow direction (do you know how we can consider that)? Thanks. |
January 10, 2016, 10:42 |
Rep Power: 14 |
Hello Rayman,
Once you defined your porous zone in "Cell Zone Conditions", you can click "Edit" and then a window will appear, you shall check "Porous Zone" and under the "Porous Zone" tab you shall find "porosity" at the bottom of the window. |
January 10, 2016, 10:45 |
fluent porous
Ray
Rep Power: 10 |
Thanks Emara, yes I know but i think that is fluid porosity and should be 1 always. Am i wrong?
January 10, 2016, 10:51 |
Rep Power: 14 |
No, it shouldn't. That's the value of your region's porosity (epsilon in the averaged governing equations). The "1.0" value means all fluid and 0 means all solid.
January 10, 2016, 10:55 |
fluent
Ray
Rep Power: 10 |
Dear Emara! Thanks. Do u know how to make a profile? Maybe we can be connected for easier discussion on cfd by email if u dont mind: rahman.ashena.313@gmail.com. I really appreciate it.
January 10, 2016, 11:01 |
Rep Power: 14 |
Sure, check your private messages inbox.
Display Modes | |
UDF for particle interception with pt_termination fortran routine | abcdefgh | CFX | 6 | October 6, 2019 13:30 |
local thermal non equilibrium model in porous media | adi.ptb | Fluent UDF and Scheme Programming | 0 | November 1, 2014 15:00 |
where to input the particle or fiber diameter D with Porous Media Models | digoy | FLOW-3D | 0 | October 17, 2013 22:38 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 09:46 |
Iclude particle diameter effect in wall? | yueroo | FLUENT | 0 | April 14, 2001 03:56 |
