February 4, 2005, 04:52 |
Aircraft propeller simulation
Hello. I'm going to simulate a 3 and 4 bladed aircraft propeller encountered with side flow. Can anybody out there help me to get some idea to simulate this propeller? I've used MRF before, however I got negative lift result. For your information, Fluent 6.1 was used to simulate this propeller?
February 14, 2005, 11:16 |
Re: Aircraft propeller simulation
yes you can do it very simple. once you have the geometry all you have to do is to put your propeller into a cilinder and give a rotation mouvement to the reference. in the tutorials you can find a model for rotor stator flow. is the same thing only that your rotor is the propeler and the stator is the plane. yes i've done a hovercraft propeler in fluent and those ware happy with the results
cip |
January 13, 2014, 04:20 |
M Mohsin Iqbal
Location: National University Sciencies & Technology, Pakistan
Rep Power: 12 |
Hi . i want to do propeller simulation in CFD and then extract results like
VORTEX INTERACTION THRUST DISTRIBUTION PRESSURE DISTRIBUTION VELOCITY CONTOURS etc So plz guide me how can i do it i.e Meshing type ?? boundary conditions in FLUENT ???? . REGARDS Pro-engineer you can email me also sir at twinklingbeacon@gmail.com |
January 4, 2016, 02:14 |
samrat himvanth nanduri
Rep Power: 13 |
hi ,
im working on a simulation of a helicopter propeller in FLUENT, I would want to understand what is the kind of mesh domain that is most suitable for this kind of a problem...also can u please help me as in how to set up the model in fluent...What kind of technique is being used for rotating elements and how to set up the problem..Thanks a ton... |
Display Modes | |
Quadrotor helicopter propeller simulation | Attesz | CFX | 14 | December 4, 2017 15:45 |
Propeller Simulation | Craig Paxton | FLUENT | 11 | February 16, 2010 23:57 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 13:46 |
3D aircraft simulation | harrislcy | FLUENT | 1 | November 11, 2009 12:31 |
Propeller flow simulation | jun005 | Main CFD Forum | 0 | August 5, 2009 02:10 |
