January 15, 2016, 09:02 |
How to model and internal pump?
ujjawal aggarwal
Rep Power: 10 |
I am doing a project in which I want to model flow in a device with a centrifugal pump fitted to cause all the flow. The device also has openings to the atmosphere. I have to basically model the effect of the pump on the fluid and not the insides of the pump. I am a newbie to fluent but I have simulated for the same project in Autodesk Simulation CFD also. I came to fluent because my institute has a licence for it and also fluent has axisymmetric swirl model available(mine is this case). In Sim CFD I used to define the pump domain MATERIAL as a centrifugal pump. Also I only had to give mass flow rate input. In fluent there is no such thing as defining the material as "centrifugal pump" so I suppressed the geometry and applied velocity inlet BCs to the corresponding edges. But this causes the continuity residuals to stay large(round off errors in velocity inlet input). Is there a better way to do this? Will there large continuity residuals really cause that much trouble or have negligible effect? Also my model runs fine with k-omega SST model but diverges for the reynolds stress model(fluent manual suggests RSM for high rpm swirl flows), so is it due to this velocity inlet thing?
Please help |
internal pump |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Advice on turbulence model for complex internal flow | JPBodner | Main CFD Forum | 1 | September 3, 2011 03:07 |
Internal CFD on a surface model (SW2010) | sw1990 | Main CFD Forum | 7 | January 4, 2011 19:36 |
turbulence model in internal combustion engine | George | Main CFD Forum | 0 | December 4, 2006 18:01 |
