January 28, 2016, 04:46 |
interface
shahin
Rep Power: 10 |
hi,
I want to define interface between two Cylindrical faces .I created two faces with different mesh in same position,but fluent did not know them as interfaces and check mesh has error. can you help me? |
January 28, 2016, 04:49 |
Rick
Rep Power: 26 |
You must create the interface in fluent.
You have two different overlapping surfaces, in fluent go to the interface panel, choose the 2 surfaces, choose a name for the interface and create it, then check the mesh.
Google is your friend and the same for the search button! |
January 28, 2016, 05:31 |
shahin
Rep Power: 10 |
thank you.
i did this before and check mesh gave error, but this time it work! i don't know why! Last edited by shahin; January 29, 2016 at 15:32. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
