January 29, 2016, 06:00 |
Graph analysis !!!
Jongmin Choi
Rep Power: 10 |
Hi, I 'm a beginner of the ANSYS
Whenever I run caculation, I have confronted a complex graph that is shown on the console window in ANSYS. It seem secret password for me. Could you expain the graph that I will attach briefly? I mean I wonder why these lines pop up periodically and why these lines decrease slightly overall except for the 'poping up section.' I also attach the tutorial problem which is about the graph. Thank you teachers!! |
January 29, 2016, 09:21 |
Rep Power: 26 |
Those are the residuals, they (roughly) show how far converged your solution is.
Lower is better! In your case, you see that in most iteration steps, the residuals are going down. This is good: your simulation is converging. If it would be diverging, residuals would go up all the time. In some iterations, the residuals go quickly up a lot. This usually means that some settings were changed, and from the picture it looks like in your case the mesh was adapted. If the mesh is adapted, the 'old' solution is no longer so good, that is why you see increased residuals. |
January 31, 2016, 03:32 |
Jongmin Choi
Rep Power: 10 |
Thank you pakk You are so kind
January 31, 2016, 08:06 |
Rajat
Rep Power: 10 |
The reason you see peaks at frequent intervals is because the current time step is over and the next iteration has begun, i am not sure what the iterations per time step or time step size is ,but u should probably increase the iterations per time step so that the solution is a bit more accurate.
February 1, 2016, 01:33 |
Jongmin Choi
Rep Power: 10 |
Thanks Noobism !!! I will try what you've recommended!!
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 08:46 |
Acoutic fan analysis | arunraj | CFX | 3 | October 4, 2012 18:54 |
Acoutic fan analysis | arunraj | FLUENT | 0 | October 4, 2012 05:54 |
Eigenfrequencies static and modal analysis | Laura_mecheng | ANSYS | 1 | May 15, 2012 03:40 |
Short Course: Computational Thermal Analysis | Dean S. Schrage | Main CFD Forum | 11 | September 27, 2000 17:46 |
