Defining output as wall, pressure outlet, or? |
February 15, 2016, 16:59 |
Kieron
Rep Power: 11 |
I have a rectangular 2D model, the rectangle is filled with phase change material. I have set one side of the rectnagle as the input using wall but I'm not sure about the output. I have tried wall also as I require an ambient temperature of around 20C but got some interesting solid in the results suggesting the below melting point temperature is negatively effecting that side of the rectangle. I then tried pressure outlet as I read about backflow temperature.
What is the right answer here? |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Pressure outlet BC help! | eishinsnsayshin | FLUENT | 7 | December 3, 2012 23:36 |
Help ASAP! pressure inlet & outlet | engahmed | FLUENT | 0 | June 13, 2010 15:33 |
