March 6, 2016, 09:44 |
Export VOF=0.5 contour coordinates
Jordi Pina
Rep Power: 11 |
Dear all,
I am interested in exporting the contour of VOF=0.5 in a text file. I mean, the x and y coordinates where the VOF=0.5. Does somebody have a clue? Thanks a lot! |
March 6, 2016, 10:08 |
Lucky
Rep Power: 65 |
Define an iso-surface. You need to do this after you have finished iterating because the iso-surface does not update with each iteration. The iso-surface is just an ordinary surface like a plane surface of line with a fixed definition of (x,y,z) coordinates after it has been defined.
Then export your VOF on this iso-surface. |
March 6, 2016, 10:17 |
Jordi Pina
Rep Power: 11 |
Is it possible in a 2D analysis? Surface-Isosurface is not available for me.
March 6, 2016, 10:47 |
Lucky
Rep Power: 65 |
March 6, 2016, 15:21 |
Jordi Pina
Rep Power: 11 |
Found LuckyTran, I think my problem is already solved
Export coordinates of contour plot | Dorit | Tecplot | 2 | September 19, 2016 12:55 |
x, y, z coordinates in automatic solution data export | ImolaSpa | FLUENT | 0 | March 9, 2015 00:06 |
Unable to install OpenFOAM 1.6-ext | Maimouna | OpenFOAM Installation | 23 | May 8, 2014 05:47 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Add Measure Markings or Coordinates to the Contour | Colin | FLUENT | 4 | August 25, 2004 09:54 |
