March 7, 2016, 22:11 |
Interface duplication in Fluent
Carles
Rep Power: 10 |
Dear All,
When I draw my geometry, consisting in 2 phases (air and water droplet) as I attached, I see later in Fluent that it creates two times the interphase between liquid-air (droplet surface). The two interface are the same but they have different names, contact region 2 src and contact region 2 trg. The problem is that I have a lot of pressure increase across the interface with little time, so I think that this can cause it, so how can I delete one of them? Thanks for all |
March 8, 2016, 00:50 |
Lucky
Rep Power: 65 |
Do you have them as separate zones or a single zone?
If separate zones there should be two surfaces to the interface (a source and a target). Even if not, most interfaces come in pairs (always a source and target), otherwise there is no interface. |
March 8, 2016, 01:50 |
Carles
Rep Power: 10 |
So is it normal then?
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
[ICEM] domain interface in ICEM for fluent | hsn | ANSYS Meshing & Geometry | 24 | November 27, 2012 16:43 |
Call Fluent from Visual Basic 6 interface | AbuKhawlah | FLUENT | 0 | June 5, 2005 14:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
