March 10, 2010, 19:56 |
Modeling nanofluids
Rep Power: 16 |
Hello
I am new to FLUENT. I just a clarification for modeling nanofluids flow in a tube. What model should i use? Discrete model or Two phase model? Can anyone explain the difference between them? Thanks |
March 10, 2010, 23:26 |
Rep Power: 17 |
hi
In Multi phase modeling There are two approaches 1)E-Lag method (Euler-Lagrangian Method) - Discrete Phase method The Fluid phase is treated as continuum and the particles are solved as tracking the particles in the flow I.e. Fluid Euler method and Particles as Lagrangian method 2) E to E method (Euler Euler method) multi phase models a) Mixture model b) Eulerian model Above two are useful for your application and the third one is c) VOF The discrete phase model if applied should have fairly low volume fraction of dispersed phase, usually less than 10-12% of total volume, which is a criteria for DPM Model. If the volume fraction is more go for Mixture Or Eulerian Model in multi phase modeling. Uday |
March 11, 2010, 00:59 |
Rep Power: 16 |
Thanks Uday!
the info is very helpful! I have to use volume fractions below 10% so I can use DPM now! |
March 23, 2016, 06:21 |
Rajendra Singh
Rep Power: 10 |
regarding Multi-phase mixture model
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
Solid Modeling | Chris | Main CFD Forum | 10 | July 2, 2002 07:12 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
Extrusion Modeling | Elliot Schwartz | Main CFD Forum | 1 | September 11, 1998 19:08 |
