Total Heat imbalance even if solution 'converged'
Old   March 22, 2016, 09:20
Unhappy Total Heat imbalance even if solution 'converged'
Amit Kunte
AmitKunte is on a distinguished road
Hi friends ,
I am simulating a gaseous combustion problem, and the solution seems 'converged' if the residuals (energy:<1e-09 and all other: <1e-07) and the 'total sensible heat transfer rate' across all surfaces ( imbalance < 0.1 Watt) is considered. But the Total heat transfer rate refuses to converge even after running an extra 100000 iterations after reporting the above values. I have made the walls of the reactor adiabatic (to simplify things) but the difference between total heat input thru the velocity inlet and the total heat outlet through the pressure outlet is still substantial. (The exit temperature of the straight channel combustor does not match with the adiabatic flame temperature at the same conditions) I have already done a lot of simulations since 8 months ensuring that the above criteria are met but ignoring the 'total heat transfer rate' balance and there is a disparity in all the results. This has brought the veracity of all my past simulations under question. I have attached a screenshot of the 'FluX REPORT'. Please can someone address this problem??!.
Also, heat seems to be losing near the velocity inlet , even though the thermal BC there is a constant 300K( and constant inlet velocity normal to inlet). Turning inlet diffusion off does not change the result much.
AmitKunte is offline   Reply With Quote
Old   March 30, 2016, 16:39
Amit Kunte
Can anyone help here??
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Total heat release rate - variation not expected Bufacchi OpenFOAM Running, Solving & CFD 14 May 15, 2020 06:35
Unable to get converged solution using SimpleFoam jr33 OpenFOAM Running, Solving & CFD 6 December 12, 2016 04:48
Difference between Total Heat Source and Volumetric Heat Generation? sieginc. STAR-CCM+ 1 March 26, 2013 03:20
Naca 0012 (compressible and inviscid) flow convergence problem bipulsaha FLUENT 1 July 6, 2011 07:51
