March 23, 2016, 11:05 |
Fluent report
Karina
Does anyone know of a way to get a copy of the setting used in the physics and boundary conditions in a quick and easy format. I have to record lots of little tweeks and it would be really useful to type something into the command prompt and have the settings used come out for that particular run. Thanks! |
March 23, 2016, 17:01 |
Lucky
Rep Power: 65 |
try typing into the TUI
file write-settings "filename.txt" I don't know if you can consider this quick and easy to format though. A journal file may be easier. One thing you can do though is to use a settings file to import most of the settings and then modify only the relevant parameters that you want to change. |
March 24, 2016, 07:23 |
Karina
Thank you I will try this!
fluent, report, settings |
How to start Fluent with Matlab?? | Jay Hu | FLUENT | 8 | November 9, 2022 07:30 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 07:47 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
how to report center of pressure in FLUENT? | xiaofish | FLUENT | 1 | September 17, 2007 06:36 |
