.Cas naming issues
Old   April 5, 2016, 17:24
Default .Cas naming issues
Jordan
jnull is on a distinguished road
I am new to Fluent and am trying to write a journal file (which is another issues in and of itself) to run several cases in a batch mode. The problem is after I set up the cases in the workbench it is autosaving the .cas.gz files with arbitrary names such as SYS-6.1-12.cas which makes it very confusing and cumbersome to manage. Where are the settings to name the .cas files manually?
Additionally, all the cases are saved into different sub-folders of the main project (ex: C:\CFD\PROJECTNAME\dp0\FLU-(8,9,10,etc). Will this pose an issue when I write my journal file to run all of these?
Thank you
Jordan
jnull is offline   Reply With Quote
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 16:18
Improper data to cluster through .cas and .dat files kaeran FLUENT 0 October 24, 2014 04:10
[General] Some Paraview Issues I can not solve MR_Chicho ParaView 1 September 24, 2012 05:03
File naming convention roncresswell OpenFOAM Installation 3 December 6, 2005 05:01
someproblem about the copy the .cas file ztdep FLUENT 2 October 19, 2005 08:00
