April 18, 2006, 01:36 |
Obtaining Reynolds Number in FLUENT
Given Mach number (Fixed), angle of attack, chord length (1m), Reynolds number, I have modeled the flow of air around an airfoil using the Spalart-Allmaras model. I used the FLUENT tutorial, there is no way to input the Reynolds Number directly. How do I obtain the Reynolds number, and how do I vary the Reynolds number? I know Re = (U*L*rho)/mu, I used farfeild in the "Compute From" of the Reference Values. Should I just substitute with the numbers given there to obtain Reynolds Number?
April 21, 2006, 18:53 |
Re: Obtaining Reynolds Number in FLUENT
As you have written, you can change the density and/or viscosity. (If Mach no was not a concern, you could change the velocity and could still work with air) greetings. |
April 7, 2016, 02:46 |
Mach number
Amit soni
Rep Power: 10 |
But U is not matching when i calculated with M and Re
Display Modes | |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 09:54 |
Reynolds Number and Heat transfer Coefficient | panos_metal | FLUENT | 0 | January 7, 2011 07:37 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
What is "Resolved Reynolds Stress" for LES model in Fluent? | ivanbuz | FLUENT | 0 | November 1, 2009 17:36 |
Fluent 6.4 courant number | Aris Nikolopoulos | FLUENT | 0 | May 6, 2008 09:52 |
