Error in Parallel Processing
Old   April 12, 2016, 12:59
Default Error in Parallel Processing
Christoph Ferk
chrisf90 is on a distinguished road
Hello everybody,
I am facing some problems with parallel processing. I run some simulations on a single machine mith multicores (I use 12). And everything is working fine until I switch on the DO radiation model. I have attached a screenshot of the Error message which occurs in TUI.
I am also wondering because i got other simulations running parallel on more cores previously also - also with DO model. It seems for me like a random problem, but I want it to work everytime.
Maybe it is a hardware issue but as I am not really a hardware specialist it is only a guess.
Advice would be highly appriciated.
Regards
Chris
chrisf90 is offline   Reply With Quote
Old   April 12, 2016, 16:01
Lucky
Not sure what the problem or fix it. The error message just sates that the parallel cores couldn't communicate, which can be caused by anything. If this is recurring problem, then you would need to do some serious debugging and logging everything that you did to determine what the root cause is. If it's infrequent, just move along. Hopefully you get a more detailed error at some point to help you isolate the problem.
Maybe you can try reducing the number of divisions/bands in your model?
Old   April 13, 2016, 01:21
Christoph Ferk
Thank you for your reply.
Alright, I will move on with some other cases in my parametric study and will see if the same or other errors will occur.
I will try that with reducing the number of divisions/bands in my models. But compared to other studies in literatur the number of those in my model are quite small (divisions 4x4; bands 2).
Maybe starting with small values and partly increasing could help?
However, I go to work right now and will see if I get it running. Thank you anyway at this point.
Old   April 13, 2016, 12:15
Christoph Ferk
Dear LuckyTran and other users
I tried to reduce the number of divisions and bands in my models and obtained that the problem occurs from the number of divisions.
Everything works fine until I increase theta and phi divisions over 1x1. Then the simulation crashes and states the error from post#1.
With this information - does anybody have hints for me which could help solving this problem?
Thanks in advance
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
problem for parallel processing minaret OpenFOAM Running, Solving & CFD 14 January 19, 2015 23:41
HP MPI warning...Distributed parallel processing Peter CFX 10 May 14, 2011 06:17
About parallel processing in Linux tuks CFX 10 August 8, 2005 08:22
