April 12, 2016, 14:40 |
Buoyancy effect
Musa Idris Dirar
Rep Power: 10 |
I want to simulate cold air (290 K) enters a room with velocity 0.4 m/s , and to bend downward when it comes out from diffuser (the inlet) by the buoyancy effect, how this can be made in ANSYS Fluent 14.0 ?
April 12, 2016, 15:57 |
Lucky
Rep Power: 65 |
Activate the gravity option (where you select pressure-based/density-based and steady vs transient). Enable the energy equation in the models.
You also need to use an appropriate equation of state. At the minimum, the Boussinesq approximation should be used for the density. Or you can also use ideal gas law, etc. This is in material properties. |
April 13, 2016, 00:41 |
solution control
Musa Idris Dirar
Rep Power: 10 |
Thank you Lucky Tran , the inflow bent downward due to buoyancy effect , but the solution didn't converge ( i used 10000 iterations and residuals as default) , i want to control the solution to converge , can anyone help me?
Buoyancy in gas turbine rotor | snusmumrick | CFX | 7 | May 29, 2012 07:23 |
Buoyancy Turbulence | Chilli83 | CFX | 3 | April 14, 2009 20:28 |
buoyancy effect in k-ε model | Majid Bahari | Main CFD Forum | 0 | March 11, 2009 10:38 |
stack effect - natural ventilation - buoyancy | segis | Main CFD Forum | 0 | January 28, 2008 04:21 |
Buoyancy production for species concentration | George Gerber | FLUENT | 1 | May 25, 2006 16:56 |
