April 28, 2016, 09:38 |
Thermal Stratification
Moquay Ugo
Rep Power: 9 |
Hi !
I'm a trainee and i need to study the thermal stratification inside a volume full of air. It's an helicopter cockpit. So I have to use gravity function in Fluent I choose incompressible ideal gas for air, and sutherland viscosity I prescribed 0.039kg/s-340K of air at the entrance (a pipe), then it goes into the cockpit, and then through a pressure outlet with ambiant temperature -293K I use energy equation, k-e realizable model, Coupled and Presto for pressure and 2nd order for the rest but I can't see any thermal stratification in the results Can you help me ? |
April 29, 2016, 17:24 |
Lucky
Rep Power: 65 |
Did you remember to enable gravity?
The outlet temperature is inconsequential unless there is backflow. What are your thermal boundary conditions? These are very important because you have an inflow at uniform inlet temperature. Thermal stratification will not occur unless there is some heat transfer that produces a temperature gradient. |
May 2, 2016, 03:49 |
Moquay Ugo
Rep Power: 9 |
Yes gravity is enabled.
My boundary conditions are mass flow inlet with 0.039kg/s-340K and a pressure outlet at 293K the other are simply wall, adiabatic and convection |
May 2, 2016, 09:52 |
Lucky
Rep Power: 65 |
Check your thermal boundary conditions.
Remember, if there's no heat transfer, you don't produce any thermal gradients with a uniform inflow, then there won't be an thermal stratification. |
air, fluent, stratification, thermal |
thermal stratification of a water container | pkladisios | ANSYS | 3 | August 6, 2015 18:51 |
thermal stratification and interface pahse-change | wolfindark | OpenFOAM Running, Solving & CFD | 2 | October 3, 2013 06:18 |
Convergence problem of a thermal stratification tank simulation | hwangpo | CFX | 2 | April 25, 2013 07:23 |
Thermal Stratification: CFD vs Measured Data | Apple Chan | Main CFD Forum | 0 | May 3, 2000 08:44 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
