Convergence problem
Old   April 29, 2016, 02:47
Default Convergence problem
SHEIKH NASIRUDDIN
nasir.iitd is on a distinguished road
Hello everybody,
I'm simulating a pipe flow with a v-cone flow meter co-axially placed in it. I 'm using RNG k-epsilon and STD k-omega model in Ansys 15.0 fluent. If the flow velocity is below 1 m/s the solution converges easily within 2000 iterations but if the flow velocity is set to 2 m/s, 3 m/s or 4 m/s the solution does not converge even upto 50,000 iterations. The residuals are set to 1e-06.The under-relaxation factors are set to default setting for 1 m/s fluid velocity, there after I reduced it for higher velocities, results did not show any improvement. Need help to get a converged solution.
nasir.iitd is offline   Reply With Quote
Old   May 2, 2016, 05:20
Paritosh Vasava
vasava will become famous soon enough
How is the mesh? Post some pictures of mesh, information about mesh quality and picture of the convergence graph.
vasava is offline   Reply With Quote
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 02:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 06:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 03:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
