Home > Forums > FLUENT
Problem with solar loading- sun does not heat a block.
Old   May 18, 2016, 12:44
Default Problem with solar loading- sun does not heat a block.
Wojtek
Gerro31 is on a distinguished road
Hi.
I was trying to check how the temperature of a block would change in time. I constructed a box slightly above a ground, turned solar load, gravity, changed air density model. The results that I got are quite weird- Fluent seems to see a box, but it is not heated and the ground heats up to incredible temperature. Could you please tell me what the problem may be?
https://i.gyazo.com/fa4dd089eec788a9...0038bc1fa0.png
Gerro31 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Mixer mesh - negative volume problem jadtwo OpenFOAM Native Meshers: blockMesh 2 November 6, 2014 17:37
Problem with snGrad() for heat flux. SKLee OpenFOAM Programming & Development 4 March 4, 2014 23:46
[ICEM] Multiple fluide zone in ICEM Hexa Block problem ddqp ANSYS Meshing & Geometry 4 October 9, 2013 10:57
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Problem with buoyancy and heat generation Jaguar CFX 8 May 12, 2011 18:54
