June 7, 2016, 10:27 |
negative static pressure problem
Jongmin Choi
Rep Power: 10 |
Hi, guys.
I tried to simulate some fluid work, but I confront weired result.... I find a result of negative static pressure which magnitude is more than operating condition pressure.... I set operaing condition as 101325Pa, a default pressure. Is there anyone who could explain this result?? I attach the result image here. Thank you... |
Negative pressure problem | hwangpo | CFX | 32 | October 25, 2023 20:56 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
How to understand the negative static pressure | taojunhust | FLUENT | 2 | August 10, 2011 22:12 |
pulsating static pressure around zero at pipe flow | David Kim | FLUENT | 0 | May 16, 2006 13:47 |
