Double pipe heat exchanger
Like Tree1Likes
Old   August 8, 2011, 06:49
Default Double pipe heat exchanger
Mohsin
mohcin is on a distinguished road
hi everybody,
I am trying to design a 2d model of double pipe heat exchanger in gambit and analyse that model in FLUENT. The problems that I am facing now are:
1): How to solve a double pipe heat exchanger in Fluent?
2): How to assign the solid material (Phase change material) in the annulus of double pipe and hot water in the inner pipe?
3): Do I have to activate the heat exchanger option from fluent or the multiphase option? I am experiencing errors when I enable the hat exchanger option in Fluent?
Kindly help me.
Thanx
mohcin is offline   Reply With Quote
Old   August 10, 2011, 01:37
Smile hi
sudhateam@gmail.com
sudha is on a distinguished road
hi!
As i understand, the double pipe heat ex-changer has two fluids and one or two solids for the pipe material.
since, you wish to model in 2D, make the mesh and define the two fluid zones separately and also the solids (the inner pipe thickness is sufficient to model if you are neglecting the radiation losses to atmosphere & just mention the outer pipe to be a wall)
now in fluent, you can choose existing material or create a new material for the analysis and apply for each of the zones int he boundary conditions.
hope this helps you,
have a great time.
sudha
sudha is offline   Reply With Quote
Old   August 17, 2011, 10:19
Mohsin
Thank u for ur kind repy. I have done these things but its still not working and giving errors like Divergence detected in AMG solver: temperature?
Old   August 17, 2011, 17:39
etienne
hittie is on a distinguished road
sometimes its caused by the model you selected: are the 2 fluids of the same kind (compressibility, turbulence)?
i had also the same problem using Fluent with a heat exchanger. Fluent has difficulties to simulate laminar flows together with a turbulent flow for example.
hittie is offline   Reply With Quote
Old   August 22, 2011, 11:20
Default Problem with the boundary conditions
Mohsin
Hi all,
I 've been trying to create a 2-D model of double pipe heat exchanger and im not sure with the boundary conditions. I 've attached the picture of my model before applying applying the boundary conditions. Can anyone help me out with the boundary conditions ??
Inner pipe - Copper
inner fluid - Water
Outer pipe - copper
Outer fluid - Phase changing material ( The problem is with this material. Im not sure whether the boundary condition for this should be a wall or anything else)
Kindly help !!
Thank you
Regards,
Mohcin
Old   August 22, 2011, 11:24
etienne
i'll will suggest you to use the velocity conditions (instead of pressure conditions-->its more stable) and you need to specify the material properties.
The velocity conditions are applied at the inlet and at the outlet. You need also to activate the energy equation
Old   August 22, 2011, 11:45
Mohsin
hi,
Thanx for reply. I have done these things I give velocity inlet and out flow for the inner pipe and I considered all other boundary conditions as copper (wall). Is it right or anything else to be considered/
Thanx
Old   August 22, 2011, 11:47
etienne
normally it looks good.
Old   August 24, 2011, 12:57
Default compression spring
mit
mithun80 is on a distinguished road
I was wondering if any of you ever did an ansys workbench simulation on compression springs. I was trying to simulate the spring compression, but the spring always interferes with both the contact plates during simulation. I know this could be done as I have seen the animation of the spring in youtube when it compresses. But I am just not able to figure it out. Any help is really appreciated.
Thank you
Mithun
mithun80 is offline   Reply With Quote
Old   November 6, 2014, 02:36
Default double pipe geometry
manish sharma
m7566 is on a distinguished road
sir how u make double pipe heat exchanger geometry in gambit. if u have any design tutorial for this geometry please send me please help me. i am using 1st time gambit so i am not constructed this geometry . please help me
m7566 is offline   Reply With Quote
Old   November 6, 2014, 02:38
  #11
manish sharma
sir please send me step by step procedure for making double pipe heat exchanger geometry
Old   November 25, 2014, 01:21
manish sharma
sir will u send me your jou file og gambitm plese sir help me
my mail id is m9713001413@gmail.com
Old   May 11, 2016, 03:33
umararshad91's Avatar
Umar
umararshad91 is on a distinguished road
Have you solved this problem? I need help
m7566 likes this.
umararshad91 is offline   Reply With Quote
Old   May 13, 2016, 12:53
manish sharma
yes not cmpltly . i have solved this problem partially complte. because my under standing to ansys fluent in meshing part and solver part limited and i don't have time because of project dead line.
Old   May 13, 2016, 12:56
Default repl
  #15
manish sharma
i have spent 10 month on this problem, if i have guidance on that time may be i am able to publish a paper.
Old   June 10, 2016, 02:59
Umar
can you please share case n data file here? or some tutorial?
Old   June 14, 2016, 12:02
manish sharma
no firstly tell me how long you reach to solve this problem.
Old   June 14, 2016, 12:51
manish sharma
last time i was helping some one he do only copy paste for thesis
Old   June 14, 2016, 13:14
Umar
I need this in a job assignment only. I want to simulate thr boiling water flow in pipe on one pipe and subcooled water in other. But when I use RPI wall boiling model of fluent I get divergence always...
Old   June 14, 2016, 13:16
Umar
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
how to analysis double pipe heat exchanger in cfx rammax8 CFX 12 February 14, 2014 16:10
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
double pipe heat exchanger Satya CFX 7 June 30, 2002 17:22
