July 10, 2016, 06:34 |
Angle of attack query
SAA
Rep Power: 10 |
Is it true that if you have a non symmetrical airfoil in 2D and then if it is needed to simulate it at angle of attack of say 5 degrees you can do this either by turning the airfoil 5 deg clockwise and leaving flow with coordinates of 1,0 (x,y) or you could leave the airfoil as it is and turn the flow by changing the flow coordinates of 0.99619,0.087156 which corresponds to 5 degrees as well ? I know that we can do the angle of attack simulations by changing flow direction and not airfoil BUT does the y component need a positive or negative direction with the same magnitude ?? What happens if its positive and what happens if its negative ?
[OpenFOAM] Plot Angle of Attack Next to Transient Pitching Airfoil | dancfd | ParaView | 6 | October 24, 2013 00:37 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
introducing angle of attack on ICEMCFD HEXA | icem beginner | CFX | 2 | December 24, 2008 11:00 |
angle of attack with icem hexa | icem beginner | Main CFD Forum | 0 | December 5, 2008 16:54 |
angle of attack | kiran | FLUENT | 0 | September 10, 2004 08:18 |
