Plot pressure distribution on a section of 3d blade |
July 1, 2010, 22:32 |
Wirot
Rep Power: 16 |
My wind turbine blade has spanwise direction in z ,chordwise in x ,thicknees of airfoil in y. After simulation, I use XY plot -> pressure -> static pressure, choose monitor at z= 30% span (which i has created already with Iso-surface) to show pressure distribution over airfoil at this section.The xy plot show as the attached picture below which is very confuse for me. What should I do? Any one can help me?
So, I really need your valuable guidelines! Sincerely yours wirot |
July 8, 2010, 10:05 |
Jouke de Baar
Rep Power: 16 |
My guess is that you have now plotted all values on the iso-surface, whereas you are only interested at the values that are actually on the foil surface.
Perhaps you can instead create a clip surface, where you clip the foil surface from, say, 29.9 % to 30.1%. (Or maybe even 30% to 30% although I'm not sure this will work.) Good luck! Last edited by jack1980; July 8, 2010 at 10:06. Reason: clarify |
July 22, 2016, 05:03 |
Ramin
Rep Power: 10 |
Hi
you can do it in 2 ways: 1-opening it in tecplot and using a plane for each section 2-in Cfd Post.you should define a plane--->define a polyline at the intersection of plane and blade---->define a chart with x axis of blade's chord and y axis of pressure or somthing else at the intesection on plane and polyline which makes an airfoil that you want to have pressure chart of it Best Regards Ramin |
Plot on a curve | Monica | FLUENT | 1 | July 11, 2012 00:24 |
Pressure Rise Error | emueller | CFX | 0 | May 5, 2009 11:08 |
plot pressure distribution on a section of 3D wing | ROOZBEH | FLUENT | 3 | April 21, 2008 03:30 |
Pressure plot by wing slice | Matt | FLUENT | 1 | November 26, 2005 20:04 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
