Boundary conditions for a Water hammer with a non viscous fluid |
August 4, 2016, 12:47 |
Nader Khattabi
Rep Power: 10 |
I am currently trying to simulate the water hammer phenomenon for an inviscid flow with Fluent.
To do so, I have used a power point presentation provided below along with the numerical results for this case. I started with initial BC: pressure inlet , and mass flow rate outlet-open. after the convergence, i changed the BC for the outlet in order to create a closed valve (as shown below) and then i run the calculations again. Unfortunately, the simulation does not seem to be valid compared to numerical results. the pressure variation chart (provided below) that i found, shows a pressure drop which is not logical, as there should be no pressure drop if we are using an inviscid flow. Does anyone have an idea of what could be the problem ! Thanks |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Multiphase heat transfer | pkladisios | CFX | 8 | June 7, 2016 01:41 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
