y+ value ~1 question
Old   September 2, 2016, 01:13
Default y+ value ~1 question
Edward Kraft
ekraft is on a distinguished road
So the wall function I'm using requires a y+ value to be as close to 1 as possible. If my max y+ after simulation is around .02, does that change my results significantly than if my max y+ was lets say 0.9? Does the closer max y+ is to 1, the better the results, or as long as my max y+ is less than one, I'm good to go? Thank you.
ekraft is offline   Reply With Quote
Question about symmetry in Autodesk Cfd 2016 ecto Autodesk Simulation CFD 0 October 20, 2015 04:16
small question about the functionalities of topological changes in OpenFoam ngj OpenFOAM Running, Solving & CFD 2 February 28, 2013 10:02
Question Re Engineering Data Source imnull ANSYS 0 March 5, 2012 13:51
internal field question - PitzDaily Case atareen64 OpenFOAM Running, Solving & CFD 2 January 26, 2011 15:26
Poisson Solver question Suresh Main CFD Forum 3 August 12, 2005 04:37
