Slurry Flow Simulation
Old   September 15, 2016, 09:30
Default Slurry Flow Simulation
Ganesh Narayana
Ganesh.aero is on a distinguished road
Hi there,
the case before me is a process called in-situ leaching, which is used for uranium extraction from its ore. As part of the process, a leaching agent usually dilute sulphuric acid is used to separate uranium particles from its ore, the suspended uranium particles in sulphuric acid is then transported to the processing plant. My part is to simulate the slurry in which uranium particles are suspended in sulphuric acid through a horizontal pipe. the temperature of the slurry is 423K & the volume fraction of uranium particles is unknown to me for which i have assumed it to be more than 12%.
I have to employ Eulerian granular model to solve this,
how do i go about simulating this?
Suggestions would be highly appreciated!!
Ganesh.aero is offline   Reply With Quote
Modelling Slurry flow sandisk FLUENT 13 September 23, 2019 23:51
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 17:02
Some questions about flow boiling simulation in Fluent beastieboys6 FLUENT 8 November 20, 2017 23:47
Flow rate restriction simulation set-up siw CFX 4 February 16, 2016 12:15
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
