How can I import table from Excel to Ansys-fluent? |
October 20, 2016, 04:08 |
ramin
Rep Power: 9 |
Hello experts. I am working on blood flow.
I have pulse pressure boundry condition in outlet (pressure depends on time) and pulse velocity in inlet( depends on time). I don't have pressure or velocity formula , therefore I can't use udf for define boundry condition. I just have 2 charts for time-pressure and time-velocity and I have points of this 2 charts in Excel. How can I import this data's table to Ansys fluent as boundry conditions? please help me. thank you |
October 20, 2016, 13:50 |
Lucky
Rep Power: 65 |
You can make a .prof file and read it into Fluent it's just a text file with coordinates or time and all the field variables.
Check out Section 3.6 in the Fluent User's Guide on reading and writing profiles. and Section 6.6 specifically on Profiles. 6.6.2 is the format for the x,y,z profile. Also search this forum for examples. 6.6.5 has the format for a transient file, which I have copy and pasted here. ((sampleprofile transient 3 0) (time 1 2 3 ) (u 10 20 30 ) ) The parentheses aren't actually necessary but can speed things up because it allows Fluent to skip groups that are not needed. |
October 21, 2016, 01:24 |
Paritosh Vasava
Rep Power: 22 |
I am guessing that you are simulating blood flow. Are you?
I have not seen excel directly connected to fluent. But I recommend that with excel you obtain a curve that best fits your data and create a UDF using these functions. DEFINE_PROFILE is most commonly used for time-dependent boundary conditions. |
October 21, 2016, 01:31 |
where should I write a .prof file
ramin
Rep Power: 9 |
thank you for your attention.
I read fluent user guid. in user guid just describe the method for writing prof file. now I have another question. where can I write profile file or which software can I use to write profile file.? |
October 21, 2016, 02:35 |
ramin
Rep Power: 9 |
thank you Vasava
I have 2 problem with curve fitting 1- my boundry condition is similar to sine function not exact sine function. 2- curve fitting isn't a exact method therefor I want to use points as a .prof file but I don't know where can I write this format for importing to fluent? can any body help me? |
October 21, 2016, 03:50 |
#6 | |
Paritosh Vasava
Rep Power: 22 |
Here is a template of the .prof file. Code:
((outlet point 2210) (x x1 x2 . . . ) (y y1 y2 . . . ) (z z1 z2 . . . ) (velocity-magnitude v1 v2 . . . ) )
Ansys SIG$ILL error | loth | ANSYS | 3 | December 24, 2015 05:31 |
import to Ansys Fluent Design modeler shows 4141 parts and bodies | samnath | FLUENT | 5 | April 6, 2015 02:22 |
error in opening fluent in ansys workbench | tmeysam92 | ANSYS | 3 | March 12, 2013 06:10 |
How to import table into Fluent | jorkolino | FLUENT | 1 | August 27, 2012 11:32 |
export data from fluent to ansys | galapago | FLUENT | 0 | August 4, 2010 14:04 |
