October 22, 2016, 20:14 |
A problem with particle tracking!
SinaJ
Rep Power: 16 |
I have a weird issue with particle tracking in Fluent. I have a stationary huge tank of water , and I want to inject particles (heavier than water, rho = 2500 kg/m3) from the surface of the tank. in my experience with Fluent, having gravity on, and pressure gradient and drag forces on, when I inject particles bigger than d= 0.005m, the particles settle, and when the particle is smaller than that size, they don't settle at the bottom of the tank (which they technically should!) Does anybody have any clue that why this happens? Thanks |
October 24, 2016, 10:21 |
Rep Power: 26 |
What do they do instead of settling at the bottom?
October 24, 2016, 12:09 |
SinaJ
Rep Power: 16 |
they pretty much stay at the surface! with random superficial motions.
October 25, 2016, 03:03 |
Rep Power: 26 |
If you take a ball at 1m above earth and let go, it will fall on the floor.
If you take dust at 1m above earth and let go, it will float around in the air. I think there is nothing wrong with your simulation. You just found that for particles smaller than 0.005m, drag forces are dominant, and for particles larger than 0.005m, gravity is dominant. |
dispersion model with lagragian particle tracking model for incompressible flows | eelcovv | OpenFOAM Running, Solving & CFD | 54 | April 10, 2018 09:36 |
Particle tracking problem | BalanceChen | CFX | 5 | February 6, 2014 06:29 |
Check particle impaction with User Fortran | Julian K. | CFX | 3 | January 12, 2012 09:46 |
Particle tracking - Domain interface / FrozenRotor | mohanrao | CFX | 4 | January 23, 2008 03:39 |
restarting lagrange (particle tracking) simulation | dbdias | CFX | 0 | September 22, 2007 19:26 |
