FIXED value in Fluent 4.5.2
Old   December 29, 1999, 08:13
Default FIXED value in Fluent 4.5.2
Risto Huhtanen
How to gain a FIXED temperature value in a CONDUCTIVE SOLID cell in Fluent 4.5.2 in a transient case? Here is a suggestion, but it does not work! Add to urstrm.F:
#include "COEFF.INC" !definitions of coefficients
in source terms of H1 equs in urstrm.F
AP(L) =0.0
AXP(L)=0.0
AXM(L)=0.0
AYP(L)=0.0
AYM(L)=0.0
AZP(L)=0.0
AZM(L)=0.0
SU(L) =0.0
SP(L) =0.0
ATERM = 1.E10*(STEMP-Tref)*Cp
BTERM =-1.E10
This means that all other terms from the enthaply equation for this cell are removed, except the A and B. So the cell value should be defined exactly. What a shame it does not work. Has anyone got suggestions?
Old   February 21, 2000, 04:11
Default Re: FIXED value in Fluent 4.5.2
Risto Huhtanen
For our information: I have solved the problem with help of Mike Slack from Fluent UK. The problem was in some other place, not in these coefficients. You can take the procedure above as an advice how to fix a value in a cell in Fluent 4.
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
