-   FLUENT (
-   -   Rotating Reference Frame (
Carolin Kosiol January 12, 2000 09:00
I am trying to simulation a rotating impeller in a mixing tank with Fluent. Does anybody of you have some experience with using a "Rotating Reference Frame" to model such a problem or can recommend some literature about it?
Thanks, Carolin Kosiol
Ahmet AÇIKGÖZ February 22, 2000 02:55
Re: Rotating Reference Frame
Hi, First of all, you should create a dummy volume around the impeller and it will be better if you give the rotation to the dummy volume. I prefer to use RNGk-e model with pressure BC's.
