Path Lines Across Sliding Interfaces
Old   January 12, 2000, 04:29
Default Path Lines Across Sliding Interfaces
Jonas Larsson
I can't get Fluent (5.2.3) to display path-lines across sliding interfaces. Has anyone else managed to do this? Is it even possible in Fluent? All my path-lines just end when they reach a sliding interface. The problem does not affect all general interfaces, only those which are sliding.
Old   January 14, 2000, 03:10
Default Re: Path Lines Across Sliding Interfaces
Jonas Larsson
Responding to myself here... I found a solution. Version 5.1.1 seems to plot path-lines also across sliding interfaces. Funny enough the simulation only works in 5.2.3.
Old   January 17, 2000, 12:11
Sung-Eun Kim
Jonas,
Apology for your inconveninece and quite possibly for others. But are you saying that 5.3 doesn't work either ?
Old   January 18, 2000, 09:03
Jonas Larsson
Sung-Eun, thanks for you reply. I just tried it in 5.3.18. It works on Linux, nice! However, unfortunately we do post-processing on HP-UX 10.20, and on this platfrom 5.3.18 gives a "floating point exception" when loading the .dat file, so I can't try it there. I have reported this to Fluent Europe.
Old   January 18, 2000, 10:33
Sung-Eun Kim
Jonas,
Sorry for the inconvenience. I checked our database and it's been logged in as a "critical" defect. We'll fix it.
path lines seeta FLUENT 1 September 4, 2011 01:07
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
mixerGgiFvMesh with two sliding interfaces christinasmuda OpenFOAM Running, Solving & CFD 0 June 12, 2009 08:13
parallel scaling with sliding interfaces laf FLUENT 1 March 23, 2007 11:50
Path Lines in FLUENT Dmitry FLUENT 0 February 22, 2006 03:34
