Boundary condition
Old   January 27, 2000, 05:03
Default Boundary condition
Thomas
I try to simulate the air flow in a greenhouse. I put the geometry of the greenhouse in a larger domain. My question is the type of boundary condition for the upper part of the domain because if I don't define it, gambit treat it as a wall. Thank you very much.
Old   January 27, 2000, 09:29
Default Re: Boundary condition
Volker Pawlik
If I understood your problem correctly you want to model a kind of an atmospheric flow. A good way to model the top of such a problem is the symmetry bc if fluxes through the top are negligible. Otherwise you have to use a pressure boundary (with the correct hydrostatic pressure if you are interested in stratification. If I remember it right, Fluent does calculate a pressure stratification only by setting p_ref=0. Otherwise it is not possible to postprocess the p-hyd_static)
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
