January 25, 2000, 05:57 |
pressure field
Ciao, I'm a student of mechanical engineering, I'm developing a thesis on CFD for ship.I'm using Fluent for a viscous analysis of a Wigley hull. I've noted that Fluent excluded hydrostatic head rho*g*z from the pressure calculation when the density is uniform (user's guide 6-18). If this is unimportant for incompressible gas,it can be a great error for my type of analisys? How am I able to overcome this problem? Maybe by user defined functions (I don't know to compile it), or by a boundary condition? Can this problem invalidate viscous resistance calculation? If you can, send to me a possible solution. Thank you very much.
Giovanni |
January 25, 2000, 11:20 |
Re: pressure field
(1). Interesting question. Can a ship still float without rho*g*z ?
January 28, 2000, 05:51 |
Re: pressure field
Hi, although it appears as if the hydrostatic pressure is not included in Fluent it actually is! The trick is, that p_hyd is excluded from the pressure-calculation and included in the bodyforce term. That is alright, since p_hyd = rho * g * h it does not change in an incompressible flowfield. If you want to display p_hyd for postproc-reasons than just define a custom-field function under Fluent's "Define"-Menue.
Greetings Detlef |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
How to get Pressure field from velocity field | qunwuhe@hotmail.com | Main CFD Forum | 4 | October 14, 2007 07:38 |
order of magnitude analysis | atit koonsrisuk | Main CFD Forum | 3 | July 27, 2000 11:59 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
