-   FLUENT (
-   -   Fluent/Gambit export to CAD (
Kai Kang February 1, 2000 16:10
Does anyone know how to export the geometry information backwards from Fluent or Gambit to CAD systems, such like AutoCAD?
Detlef Schulze February 2, 2000 04:53
Re: Fluent/Gambit export to CAD
Since GAMBIT is based on the ACIS-format which, I was told, is used by most CAD-System you should be able to export an ACIS-File which is then read by your CAD-Programm.
I hope this helps.
Scott Gilmore February 2, 2000 23:03
Correct, both Gambit and AutoCAD are based on the ACIS geometry kernel. You can export an ACIS file from Gambit and import that into AutoCAD.
Gualtiero Guadagni April 17, 2000 12:41
That is correct, but someone know how to export from Gambit to Pro/E?
Scott Gilmore April 17, 2000 14:08
Gambit 1.3, to be released in May, will have export of geometry in STEP, IGES, and Parasolid formats. STEP will be the best choice for Pro/E, as it supports solid models and is supported by Pro/E V20 and higher at no additional cost.
