February 4, 2000, 03:16 |
particle trajectories
Hi!
I calculate the trajectories of ash in a boiler. To present my results it is very important to show were the particles hit the walls. How can I display a contour of the area the particle hit the walls? All particleswhich are hitting a wall are trapped there. Thanx roman |
February 7, 2000, 09:41 |
Re: particle trajectories
Hi Roman,
you must first define a flow rate for the injection (default is 0). Then you should be able to postprocess the DPM concentration on the wall. This should be enough to indicate where the particles hit the wall. |
March 7, 2000, 12:59 |
I think you should create a surface where you want to show the particles. Then, in the Report, Discrete Phase menu, choose Sample. You have to choose the injectios you want to track, and the surface you have crated. It results in an alphanumeric result, which have the coordinates, velocities, temperatures... of all the particles which have hit the wall. Then you can display the results with tecplot or any other one.
March 8, 2000, 02:49 |
thanx!
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
PARTICLE TRAJECTORIES | srinivas | FLUENT | 2 | October 30, 2005 01:48 |
How do I get particle trajectories | Amar | FLUENT | 1 | May 20, 2004 15:05 |
Particle trajectories method | Newbie | FLUENT | 0 | January 21, 2002 22:26 |
Can we get animation from Particle trajectories? | Dazhi Guo | FLUENT | 0 | January 25, 2001 22:37 |
