Home > Forums > FLUENT
About Error Messages in Fluent(Finite Rate Model)
Old   February 18, 2000, 03:14
Default About Error Messages in Fluent(Finite Rate Model)
Pankaj Shukla
Hi ,
I am working on can combustor with finite rate chemistry model.This combustor in addition of having axial fuel and air inlets is having radial air inlets.Can Finite rate model be used in such cases.also when I give all boundary conditions it gives "SEGEMENTATION ERROR"
"BUS ERROR" How can i get rid of these.Please response asap
Old   February 20, 2000, 16:50
Default Re: About Error Messages in Fluent(Finite Rate Model)
Graham Goldin
If you use Finite-rate (Arrhenius) option and your chemistry is stiff, you should use the coupled solver. Try using the finite-rate/Eddy dissipation model.
Old   February 21, 2000, 01:34
PANKAJ SHUKLA
Thankyou Graham for your response.But for the moment I am using only methane-air Mixture from the mixture template.But the thing that is important is what are the mistakes I am making due to which these errors are coming.And whether these errors are due to gambit Modelling or Fluent solver. pankaj
Old   February 22, 2000, 10:00
Graham Goldin
If you check your grid in Fluent (Grid -> Check) and the test passes, chances are it's the solver. You want grids that have minimum skew (plot this in Gambit or Fluent).
Thread Tools
Trackbacks are On
Herschel-Bulkley non-Newtonian viscosity model has term with sign error pbryant OpenFOAM Bugs 5 June 18, 2013 23:53
Evaporation Rate Model David Wang FLUENT 0 May 9, 2005 19:30
Strain Rate in eulerian model galeazzo FLUENT 0 January 25, 2005 08:52
Laminar finite rate combustion model Shankar FLUENT 3 June 24, 2004 15:40
Pre-mixed combustion- Laminar finite rate model Shankar FLUENT 8 March 31, 2004 05:18
