Home > Forums > FLUENT
aerofoils & waves
Old   February 22, 2000, 08:49
Default aerofoils & waves
Elizabeth
Simulating aerofoils in ground effect. How do I simulate the wavy water surface?
Old   February 24, 2000, 05:09
Default Re: aerofoils & waves
Park Geun Hong
Hi! I'm studying ground effect with Fluent, too I use moving boundary option, and I think there are no methods present wavy water in Fluent. I heard next version of Fluent contains that you want.
Old   February 24, 2000, 05:11
Detlef Schulze
Dear Elizabeth, I might misunderstand your question, but why don't you just create a wavy surface by using sinusoidal cross-sections. You can read-in point-data-sets into GAMBIT, connect these to form splines and then use these splines to generate a surface. If the waves are small they might be approximated sine/cosine functions. Or do you actually want to resolve the interaction between the airfoil and the water surface? In that case you must use the VoF model within Fluent. However, the point is how to create a wavy surface then. In that case you could simply place another airfoil in the water-phase but very close to the free surface. If your mesh is fine enough and if your water flow velocity is high enough some waves will be generated.
I hope my comments are giving you some hints.
Good luck Detlef
Thread Tools
Trackbacks are On
WAVES GENERATION IN A PORT OR BRAKE WAVES. important tecnicaf1 STAR-CCM+ 1 May 27, 2011 07:32
CFD Animations of breaking waves Dommermuth Main CFD Forum 0 June 17, 2009 11:47
Papers request-Generation of water waves by source Mehdi BEN HAJ Main CFD Forum 0 June 11, 2007 12:55
Following waves generation Nico Main CFD Forum 0 October 4, 2006 08:28
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
