Home > Forums > FLUENT
Unrepenting surface
Old   February 25, 2000, 11:45
Default Unrepenting surface
Chris
I am currently modeling the flow around a combustion can of an aircraft engine. I have created a solid model of the can in Gambit. Using boolean operations I subtracted the can from a predefined volume to obtain the "air"-part. Problem is that although Gambit is quite happy with the newly formed air-volume there are surfaces that do not look very healthy, what I mean is that the surface has the shape of a "T" in the xy-plane (x from left to right) with the horizontal part of the "T" having zero thickness in the y-direction. In other words some edges lie on top of each other. I have tried to heal the volume but the surfaces are "unrepenting". Any other actions on edges and surfaces alone is greeted with the response that I should not mess around with things that are part of a volume (Gambit gives an error message).
What to do?
Thread Tools
Trackbacks are On
Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan Open Source Meshers: Gmsh, Netgen, CGNS, ... 3 October 22, 2015 11:05
Problem with Gmsh nishant_hull Open Source Meshers: Gmsh, Netgen, CGNS, ... 23 August 5, 2015 02:09
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 0 August 5, 2011 16:02
boundaries with gmshToFoam‏ ouafa Open Source Meshers: Gmsh, Netgen, CGNS, ... 7 May 21, 2010 12:43
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
